Development Updates
LightBurn 2.0.05 Patch Release
LightBurn 2.0.05 is available now. This release contains several bug fixes, listed below.
Download version 2.0.05 here.
Bug Fixes
  • Rotary jogging was flipping directions in CCW direction for rotary and XY controls.
  • Units could get corrupted for galvo devices
  • Emblaser WiFi wizard dark mode issues on Windows due to Aero theme
  • Material library combo box was too wide
  • Deform on an image could glitch on parallel lines
  • Importing SVG with ungrouped DEF shapes could crash
  • Fixed issue with device settings incorrectly sizing custom gcode options tab contents.
  • Hide other bundle controls when editing vendor info
  • Added higher resolution images for unidirectional and offset fill types.
  • Prevent app title bar from appearing off screen when stored window position offsets are incorrect.
  • Added toggle switch to disable KT332N U → Z axis mapping
  • Galvo framing now gracefully handles when you have too many shapes
  • Art library crashed if files dropped when no library selected
  • Auto-join could crash in extremely rare cases from a float rounding issue
  • Increase galvo rotary limits
  • Tab drawing wasn’t saving/restoring drawing color
  • Added more logging to BSL code for startup/connect
  • Double-click to launch if unconfigured would crash
  • Resolution fixes for cut setting windows
  • Remove the null at the end of Adobe’s SVG paste data
  • Trim would fail if snipping a shape scaled to zero in X or Y
  • Set Zero on BSL could hang the hardware
  • Fix for icons using incorrect scale value
