LightBurn 2.0.03 Patch Release
LightBurn version 2.0.03 is available now. This release contains several bug fixes and a small number of feature updates, listed below.
Download version 2.0.03 here.
Bug Fixes
  • Empty shape could crash gcode generation
  • Bundle import could crash application
  • Fixes for macro panel issues
  • Fixes for single line font issues
  • Better handling of Enter key in Repeat Marking
  • Fixes for intersection snaps
  • Fix for BSL "Done Marking" signal issue
  • Fixes for shape docking issues
  • Further High DPI scaling fixes
  • Remove clamping for discrete jogging
  • Fix for continuous jogging in G54 mode
  • Fix for head mounted camera unit conversion
  • Fix for Mac OS Ruida rate limit issue
  • Fix for synchronous mode serial transmission issues
  • Updating displayed position to 0,0 after homing on Ruida
  • Fix for hotkey and menu conflicts in translations
  • SVG 's' command didn't work for sequences of points
  • Fix for Mac OS framing hang
  • Fix for a regression with newer Trocen hardware
  • Fixed issue with docks resetting to default layout every time app is started.
  • Fixed issue causing docks to consume entire window if operating system display scale is changed.
  • Global fix for Qt image size limitations
  • Fix for glitches with font chooser on Mac
  • Fix for Stop button not properly resetting laser state to off
  • Updating the logic & text of the device size mismatch warning
  • Fix for BSL lens correction
Existing Feature Updates
  • Move "library" buttons into a menu to allow shorter vertical
  • Choose initial device units that make sense on manual create
  • Updated dash pattern to scale with DPI, made 1-pixel pen the default draw width
  • Updated BSL grayscale mode, 2nd source analog output switch
  • Allow Shift + Right-Click to flash layer
