LightBurn 0.9.06 - Ruida rotary settings for Inch mode
They say nobody's perfect, right?
When adding support for Inch mode in the rotary settings, I messed up the part that sets the pulses per rotation, and was trying to convert it from imperial to metric, which doesn't make much sense, given that "pulses per rotation" isn't in mm or inches, it's just pulses.
The other three just happen to have been fixed since yesterday, so they're being included as well.  The four changes to this version are as follows:
  • Fixed a bug when setting rotary pulses in Inch mode on DSP systems
  • Fixed a bug in the offset tool, choosing the wrong cut layer in some cases
  • Fixed a bug where cut-through mode could be left on if a cut was changed to a fill
  • Fixed an issue with Linux / AppImage not including libnsl
It's a very minor update, but the rotary setting bug could cause enough trouble that I wanted to post a fix straight away.
Cheers,
Oz
Back to blog
